› Forums › Forums › GENERAL DISCUSSION › "Twistin’ Texan" El Camino
ricky-whiteNice picture
dino
paul-ceasrine
This should be from 1968. Tex in his Stocker Day’s
1968 El Camino SS 396 ~ 396/350 HP
* Shipping Weight; #3367 lbs.
* Should be ‘D/Stock’ {9.50 to 9.99 Wt/HP}
paul-ceasrine
1969
Before the ‘El Camino’ was lettered.
D/G = 9.50 to 10.99 {Weight-to-Cubic Inches}
Tex would have had to have the ‘El Camino’ come in at {#3662 lbs.} to
qualify for D/G in 1969 with the 396 Big-Block.
The 1968 El Camino ‘SS 396’ had a Shipping Weight of #3367 lbs. and
Curb Weight of #3510 lbs.
In ‘Gas Class’, you could add #100 lbs. of Ballast, and you could also
utilize ‘2’ Heavy-Duty Batteries with a maximum weight of #150 lbs.
paul-ceasrine
C/G
1970 and later
* C/G ….. 8.00 to 9.49 Wt/HP
Maximum Ballast
* 100 lbs. of Ballast permitted
* 150 lbs. {Two Batteries permitted}
“No Hidden Ballast”
If ‘Tex’ was running a 427, the 1968 El Camino could weigh no less than #3416 lbs.
If ‘Tex’ was running a 454, the 1968 El Camino could weigh no less than #3632 lbs.
