Maso on Video…[ Fore N’ Aft ]
› Forums › Forums › VIDEO SECTION › Maso on Video…[ Fore N’ Aft ]
Viewing 6 posts - 16 through 21 (of 21 total)
  • Author
    Posts
  • #43145
    maso
    Participant
        I wanna show you something…
        I bought this Squier Stratocaster in 1996 for $250,00. Made in Korea.
        I played it every day until I wore out the frets and decided to replace the whole neck with a $35.00 replacement from China.
        ( I’m a cheapskate…! )
        But… it had no finish on it so I sanded it down incrementally to 220 grit and put a little stain on there to make it look seasoned, sorta’
        Then I applied some polyurethane with my compressor driven HVAC, wet sanded it w/220… four times…!
        Then… I used my computer and made up my own personal “Mean Mojo” logo and used my printer and my scanner with some special water slide decal paper… ( hard to find…) I put four more wet sanded coats of polyurethane over that to layer the decal in so it won’t chip off.
        It looked so good that I then decided to refinish the whole guitar and give it a new lease on life…
        #43146
        maso
        Participant
            So…
            I got out my 1200 degree F. heat gun, scraper tool and my electric hand sander and worked that old beat up Strat body through several sand paper grit increments until I has a 220 finish. I used a little Bondo too. It didn’t take a lot of time or elbow grease, it was an enjoyable project.
            I primered it then three coats of lightly wet sanded beautiful black…
            It’s beginning to look like something…!
            I applied almost two quarts of polyurethane clear coat in four wet sanded coats, each coat with three dust coats and a five minute break between dust coats just to control the dribbling.
            Now… I have to buff it out with paste and apply carnauba wax and then put it all back together again…! All the while, I’m lovin’ it…!!! 😆
            #43147
            maso
            Participant
                I got real pleasing results and I’m a proud bluesman… ! 😆
                See…
                I changed out the white knobs and pick-up covers for black ones and I’m gonna play it for another twenty years and ware it out again…!
                I couldn’t resist a new neck plate engraved with the Serial Number MM00001 and my “Mean Mojo” Logo.
                What do you think of it…??? :mrgreen:
                #43148
                tomblake
                Participant
                    Looks like quite a good project. If it sounds as good as it looks you have a winner.
                    Do you do cars on the side? 😆
                    #43149
                    maso
                    Participant
                        quote TomBlake:
                        It sounds like this: https://youtu.be/xdTCwd-zdaY
                        I don’t do cars… can’t afford them. I’m a Bluesman…! 🙄
                        #45837
                        maso
                        Participant
                            I hope some of you will have a look at my “Profile” that I set up to promote my blues guitar playing ambitions at BandMix dot com and I’d love to hear your comments…
                            Click: https://www.bandmix.com/thomas-de-lello/
                          • You must be logged in to reply to this topic.
