› Forums › Forums › CURRENT MEMBERS RIDES / RACING › Bringing Back an Early Mustang
realmongo
realmongo
How far did you haveta bring the shell???
Must feel good to get to this point of the resto.!!!!
realmongoHad to move it from home in Western Mass down to a suburb of Philly.
realmongo
realmongo
realmongoWith the car in the shop, there’s still much to do.
One of the first side projects was to strip the seats down for their restoration.
The previous owner had started a restoration and had new covers put on the seats, but the shop cut corners and installed the new covers over the old materials and rusty frames. Plus the driver’s side seat back had split and was hastily welded during its prior life and deemed unusable. Luckily I was able to get a good used replacement for it.
Nothing beats the smell of 50 year old rotting burlap! 😉
realmongoWith the seat frames free of upholstery, we were back off for another visit to Gene at Central Connecticut Coatings in East Hartford.
There they were media blasted and powder coated in semi gloss black.
I would have loved to have taken a photo of them in the after state, but I had to load up the truck and pick them up during the storm on this past Friday. I then took the freshly coated frames plus all the new upholstery, rods, burlap, cotton, etc. down to Mark at Dave’s Auto Upholstery in Watertown, CT. Mark I’m happy to say, has a steady work flow, so he said to come on back in about 6 weeks.
tomatoheadWOW really starting to go forward ,love the update with the seats and address of the places that offer that type of work needed by so many of us , I need my seats done also look at the seat my daughter is sitting in you can see the cover has come apart at the seems right now I have a Dover Drag Strip tee shirt on it 😀 ❗ thanks ❗
realmongoThe seats are being done pretty close to the intersection of Interstate 84 and Route 8 in CT. The chrome is still in the shop too in East Hartford, CT at New England Chrome Plating. I just had surgery so I’m laid up for about 6 weeks. Pam said she would make the runs to pick up the seats and chrome when they are ready. Unfortunately I won’t be able to assemble the rear end now that the housing is back from powder coat, or take one of the blocks into the machine shop until I’m back on my feet again.
realmongo
realmongoCar is now on the rotisserie, all factory undercoating was scraped off, and then media blasted and primed to assess the extent of work required (it’s amazing how many sins can be hidden under paint :o). The dreaded Mustang Cowl Leak was the first observed problem to be addressed, as the cowl was immediately cut out. Sometime in the past, someone had tried to repair it with the plastic ring kit method, but as we all know, that never works. While the cowl is out, the gaping hole in the dash will be welded up to restore the original radio location because it is so easy to get to from both sides now.
realmongoOther problems to address, are the interior floor and trunk floor. They looked good, but in addition to the toe board area rusted through due to the cowl leaks, both are pretty perforated with pin holes. Decision here is to replace with a 1-piece floor pan. The original passenger side fender can be saved and the driver’s side fender is a maybe (not because of rust, but because of a sizable crease due to an accident that was hiding beneath that was full of body filler). The passenger side front apron needs to go due to the typical battery acid damage. One original door is salvageable, while the other is not (looks like it may have filled with water and rusted through to the car’s interior). The quarters and wheel houses can all be saved with just some tweaking, but the taillight panel will need replacement due to a previously installed poor quality reproduction that has the fuel tank filler off center. One area that was unexpected is internal rust damage to the C pillar on the driver’s side due to mice having lived in there (it had come out of a barn in Middlebury, VT), so that will be attended to also. That’s probably the worst of it. Amazingly all 4 frame rails and the shock towers are in incredible shape. Speaking of the shock tower area, note that I had already drilled the holes to relocate the upper control arms the way Shelby did on his cars.
