Pictures of the Super Pumpkin 57 Chevy under restoration
Forums Forums OLD RACE CAR LOCATOR Pictures of the Super Pumpkin 57 Chevy under restoration
Viewing 15 posts - 46 through 60 (of 119 total)
  • Author
    Posts
  • #19568
    martin-d
        I’ve just realized I own a piece of Super pumpkin, not from Billy’s day’s but from the Pete Devlin/Dave Mingay’s days. I bought & still have the front wheels as in the 2nd pic down, the Cragar S/T ‘s off Dave in the early ’80’s 😀
        #19570
        dino
        Keymaster
            Pete ,Raff & Ola NOW ODF Members …Shipping out a Box of Dover Goodies to Sweden TODAY …Including Nostalgia Drags Shirts .Watch for the little ‘surprises’ I packed guys !
            #19586
            peter-lilja
                Hi Martin!
                Really nice information, indeed. In our effort to bring Super Pumpkin back to the old specs, we are trying to source parts that belonged to her back then. Ola have found the rear axle, wich we thought was a ´57 Olds but according to Billy are supposed to be a ´57 Pontiac. Have to see if we got the wrong one or if it just was wrong info. Don´t know the difference between them. Must learn. So, here is the question to come: Are the wheels for sale? Send me a pm and let us know. Do you have any other information to share, please bring it on. We have no info at all from the Mingay´s days.
                Take care // Peter
                #19588
                dino
                Keymaster
                    This is Funny…Europe talking to Europe on DDS.com 😉
                    #19589
                    patina
                    Participant
                        Peter to the best of my knowledge a 57 Pontiac has leaf springs (I have one here in front of me) and a 57 Olds has coil springs. The center sections are the same and interchangeable, 29 tooth splines I think. The axle lengths MAY be the same I can look it up. The Pontiac housing is what you want it virtually bolts in. The more desirable 59-64 Olds/Pont center section is a 31 spline with thicker axles and can be shortened to fit a 57 housing. Hope this helps. If you have any questions just e-mail.
                        #19600
                        martin-d
                            quote Peter Lilja:
                            Hi Martin!
                            Take care // Peter
                            Hi Peter
                            If you are now going to return it to Bill’s period then these are not the wheels for you, if you look at the pics, the ’72 pic shows what appear to be Centerlines on the front (single bolt pattern). The car appears to have come to the UK with slot mags on the front, then the pics of when Pete Devlin ran it ,it is running the Cragars I have (dual bolt pattern), so guessing Pete might have put them on. Steve (plumpcars) should be able to tell you more of that time.
                            Heres another pic for you, from this thread on Super Pumpkin http://www.rodsnsods.co.uk/forum/showthread.php?t=1861
                            #19601
                            dino
                            Keymaster
                                Great Site Martin …I just Registered on It …Visit it Guys !
                                #19608
                                billy-casey
                                    Patina is 100% correct … thats is the exact setup I used until I installed the summers axles and spool which was also 31 spline … the new weak link then became the driveshaft and trans … excelcior garage in mamaroneck , N.Y. made me a thick wall shaft and HD Ujoints and put in a super T-10 and the drive train problems were solved … Billy 😀 😀 😀
                                    #19609
                                    billy-casey
                                        In later 72 I was running a modified VW … he crashed in front of me , when I hit the brakes hard at the top end I blew out both front Moroso tires and damaged both wheels . Crager was not making the single bolt patern any longer at that time … The duel patern Crager is the way I sold the car… Billy
                                        #19617
                                        peter-lilja
                                            Hi guys!
                                            Thanks to everyboby for the information. Pieces of the puzzle is coming together. The Pumpkin has evolved under a long period of time, so it´s sometimes hard to say what parts is right or wrong. We are now getting a bigger picture of it all. No matter what era, all information is highly valuable.
                                            Thanks again // Peter
                                            #19669
                                            anonymous
                                                I know that I built up a diff for the car with a set of streetable gears. What I can’t remember is if I put them into the original centre piece or whether Pete had obtained a spare one. I suspect that he had obtained a spare one and kept the spool set up as well. This means that I can’t say which diff was in the car when Pete sold it.
                                                When Pete bought the car it had the dual hole wheels on although I think that Mullens ran it with slot mags on at one time. (It also had a Mopar motor in!)
                                                #19678
                                                gramdog1
                                                Participant
                                                    Hey Casey, a Mopar motor in your Chevy? Only thing worse could be a Ford. 😆 😆
                                                    Just ask Bossguy.
                                                    #19679
                                                    billy-casey
                                                        all you guys are macking me throw up 👿 👿 👿 😆 😆 😆
                                                        #19682
                                                        anonymous
                                                            Sorry Bill! 😳
                                                            The confusion with the rearend could be because over here we tended to refer to them as Olds/Pontiac, named from the centre section rather than the casings. We didn’t have as many of them about as you guys did although a number of racecars used them until the 9” gained popularity.
                                                            #20194
                                                            kingsbolt
        Billy –
        You mean all those nights grinding to make a crash box was all in vain ! Also no restoration would be complete without Mike’s and my name on the pit crew. Ha ! Ha !
        Ron
                                                              • You must be logged in to reply to this topic.
