Read it again, Dino, it’s PM, not AM 😆 😆 😆 😆 😆
Tom, I agree with you on the choice of trans fluid. I tried the Synthetic Royal Purple, and then went to the type F. I really think that the type F is the way to go. It has real “lubricants” in it since the “internals” are a little different than GM and Chrysler. Maybe clutch material, or brass content, pump configuration or what’s in the pump, not sure.
Oh, Tom, I got the problem with the trans brake “Rev Limiter” fixed, it was a wire. Never hooked up to the solenoid wire. Trans brake worked, but if i held it wide open with the brake on, it went to 5000RPM, which is the converter stall. I put a 3900 chip in it, tried it out in front of the house, and it stopped at 4000. When I let go of the button, it was like being shot out of a cannon !! My wife said it was smokin’ the tires, and picked up the left front about 6″. My C/Gas Nova used to do the same thing. But, I think with a nice burnout at the track, I’d better have the wheelie bars on when the lights come down!! ………………Mikey 😆
P.S. I’ve got a trans temp gauge in the Willy’s, and the only time it seems to move, is when I take sorta long drives around my neighborhood. I don’t remember it moving much if at all when I make a pass. I’ll have to keep an eye on that next time. 😕
tomblakeMikey….if it’s picking up the front wheels in the street, right about having the wheelie bars down on the track.
Got a brand new transbrake solenoid today, installed it but it would not work.Checked the plunger movement and it was only .144 and should be .200. Put the old one back in and everything works good. New one being returned tomorrow.
babycakesTom,gonna try her out this weekend?
tomblakePete….Still working on some small things but the car could be ready to test after about 20 minutes work. Got the center panels, seat, doors and front end off. Doing some of those things that will make it easier to work on the next time. The friend that helped me get it ready for the 4th race is working the next two weekends and I would like him to see it run when it finally runs good. Don’t know if I can wait that long but will be posting the results when we do test.
dinoVideo a test in the street!
tomblakeDino…..The street test would be fun and I know some of the neighbors do like the noise and fast cars, but don’t want to find out the ones that may not like it. Feel like I have been lucky taking the Mustang out a couple of times a week with no complaints.
dino3 am?
tomblakeYes, but post before going to bed at 3:42. Had to get up early.
babycakesTom.when I look at the time you get up.it reminds me of that ‘ole’ commercial ” time to make the doughtnuts” from Dunkin Doughnuts, remember? 😥 🙄
patinaCakes for you 😆 😆 😆
tomblakePete…As mikey said, been to the track twice since the Dover race. At Lebanon couldn’t keep the rear tires from spinning and down track it ran very good, got to 134 mph. Came home and put the slicks on the car along with changing the rear end ratio from the 4.57 to a 3.70. First through it may be too much load on the converter. The tires are not spinning and now something in the drive line is slipping. Thought it must be the converter so we changed it and went back to test again. Same problem, still slipping bad enought to reach the rev limiter on the 1/8th mile with the 3.70 rear gear.
We are working on changing the cross member to be able to install the turbo 400 and/or the PG. We had to cut the PG cross member out because it was welded in place. Now making a cross member that will be moveable to adapt to either transmission.
babycakesThanks for the update Tom,I hope it all works out for you with ‘trans’ gremlins.Just like the weather,you never know what to expect with these hot rods! Gotta give you alot of credit,your a diehard,taking on the challenges,one at a time!
tomblakeThe turbo 400 is in the car and it turns the wheels. Had it running with the drive line all connected. Just a few more minor modifications and we will be ready to test the car again, most likely this Thursday evening at the Lakeland track.
(Mikey if your ready, come on out with the Willis).
I’d love to , but I still have not rebuilt the brackets for the throttle pedal. I’ve already had, and scrapped 3 different ideas on the “fix”. Working on idea #4 right now. I want it sturdy, but I really don’t want to take the dash out, along with some of them wiring. I’m close though. …………Mikey 😆
